Brief Description: Installing the Right Main tank on the wing
Today, I installed the right main tank on the wing. It has bolts that secure the Z-brackets just like the right auxillary tank, but also uses screws to hold it in place (about 75 of them). I got everything lined up, bolted into place, then screwed in all the screws by hand. When I finished that, I also cut and installed the black plastic conduit, through which the electrical lines will be routed.
