Mike & Aneta's RV Projects
Date: 4-13-2014
Number of Hours: 6.00
Manual Reference: Static Ports
Brief Description: Installing Static Ports in the Tailcone
Today, I installed the static ports in the tailcone and began to plan the routing of the pitot/static lines. The ports were purchased from Saf-Air and are really top quality. Rather than install using rivets, I elected to use Proseal, which will not onl provide a strong structural bond, but also a watertight install. I made a slightly oversized, flexible rod out of some scrap 1/4" plywood to hold the two ports in place while the Proseal cures.
While I was inside the tailcone (very cramped quarters), I marked and drilled out some of the tailcone rivets, which I had not been able to affectively buck solo. When I replace them, I will do it with a partner. All other rivets inside were also QC'd at this time.
I also routed brightly-colored nylon string through my electrical wing conduits to the various points where I will need to pull wire later. Using a cotton ball and a vacuum, I was able to suck the string through the conduits to the various places in short order. I then tied a large washer to the ends of each piece of string, so that I know which one will pull wire to which place. This should make an easy job of wiring the wing, once all components are installed.
Inside the tailcone
Closeup on static port support rod.
Proseal oozing out prior to cleanup.
