Tonight, I began riveting together the left aileron, starting with the leading edge and then working back to the skins, which had the stiffeners riveted on previously. The hard part is sliding your hand and bucking bar down in between the skins to buck the rivets from the bottom skin to the spar flange. Would probably have been harder without a tungsten bucking bar.
