Brief Description: MD Left Gear Mount and Install Motopod Brackets
Tonight, I finished match-drilling the left gear mount and started to install the motopod brackets, which must be match-drilled at the same time, to ensure a proper fit. Some of the bolts that pass through the motopod bracket assemblies will be removed along with the main gear mount, and installed permanently later on, so those are not torqued at this time.
