Brief Description: Dimple and Reassemble Fuselage Halves
Tonight, I dimpled all the parts that needed it, then reassembled the two fuselage halves using the rolling dollies. It was much easier, after everything had been match-drilled, deburred and dimpled. I will need help in order to rivet this beast together.
