Brief Description: Cleco Longerons and Baggage Door Seal Angles
Today, I installed the longerons for the center fuselage section, so they can be match-drilled with the skins later. This involved fabricating several angles, to be used for the baggage door seals, as well as fabricating several brackets, including the back seat support bracket.
