Brief Description: Rivet Floor Ribs to Front Fuselage Skin
Tonight, I finished riveting the floor ribs to the heat shield section of the belly. I think it came out good, and once the paint is on, you'll hardly be able to tell that the extra protection of the heat shield is there. However, if there's a fire in flight, I'll be glad it's there. After completing this, I moved on to riveting the ribs, aft of the heat shield and also the various brackets to the bottom skin of the front fuselage section. I only got in 3 hours, but it felt good to be back in the shop after some time away from the project.
