Mike & Aneta's RV Projects
Date:  11-21-2016
Number of Hours:  3.00
Brief Description:  Finished Panel and Installing LEDs
Tonight, I finished up the avionics panel installation. Everything is held in place with industrial strength velcro. Very strong stuff. I've begun mounting the LEDs, but will need to clean up the install to hide the wires a little better. I am planning the super glue the wires to the flat surfaces, then paint them gray, so they blend in. The only place the wires are really apparent is on the wing, but I'm not worried, because the wires are underneath the wing and this plane sits pretty low to the ground, so you wont see them.
Finished Avionics Panel, from underneath.
"Landing Llight" LEDs
Position Light & Strobe LEDs
