Mike & Aneta's RV Projects
Date:  10-30-2015
Brief Description:  Match-drill Holes & Glue Dowels
Today, Amelia and I got to spend some time on her pedal plane project. She match-drilled more holes, using the drill press. Then we cut up some more dowel pieces and glued them into place. When these parts are dry, they will hold the axle, which powers the "engine." Robert also has taken notice and loves to play in the shop too. Although he requires a lot more supervision than Amelia these days. Boy, we've come a long way since she used to bump her little plastic car into the RV-10 parts...
BUSTED!
BUSTED!
Glueing together the pedal axle brackets
