MIKE'S WEB SITE
Date:  5-23-2004
Number of Hours:  14.00
Manual Reference:  47
Brief Description:  Installing Canopy Release
Made C 620 Bearing Block Fabricate, prime and paint canopy release mechanism componets C620, 621, 622, Wd618, Wd619, Wd 620, and modified AN3B-16 bolts Aligned and clamp bearing block to F697, drill and bolt assy in place Used Tip up canopy latch hole pattern template on Dwg 48 and drilled holes in left side fuselage skin and cut out slot and filed to size
