MIKE'S WEB SITE
Date:  2-2-2004
Number of Hours:  8.00
Manual Reference:  39
Brief Description:  Constructing Cabin Frame
Cut access holes in aft F631A channels made all mounting angles on Dwg 39 Made F631E plates, centered F631E on center joint and drill plate to channels Clamped and drilled F631B inner strap to lower channel, then repeat for upper channel (both pairs) Check height as per dwg 39 Disaasembled, deburred and primed, rivet assy together
