MIKE'S WEB SITE
RV9-A
Punch List, much misc
Install F695 L&R Firewall top gussets Remount (reverse) nutplates on firewall Fuel Pump Bracket Cut and retrim Rudder Pedal brace F6118 Finish F607 Upper Fwd Fuselage Redo F983 Fuel Selector bracket (Needed top section for manual trim knob) Install Static Lines Install Fuel Boost Pump Install Rudder block and tighten assy Reconnect, lube and tighten vent and brake lines Install Rudder stops
RV9-A Home
1164
540
Insturment Panel
Systems
366
