MIKE'S WEB SITE
Date:  4-7-2003
Number of Hours:  8.00
Manual Reference:  12
Brief Description:  Finish prep on Tank, ready to seal
Drilled out platenut rivets on ring, mounted ring to inboard rib and THEN riveted ring. drilled holes for BNS connector (Capacitance plates wiring), soldered wire to connector. Drilled hole for vent and fuel pickup fittings, drilled rivet holes for Anti-Rotation Bracket. Dilled holes for Drain plug and fuel cap. Cut, flaired and positioned vent tubing. Notched grommets for Capacitance wiring. Disassembled tank. deburred and dimpled. Ready to clean and start sealing/riveting.
