MIKE'S WEB SITE
Date:  1-20-2003
Number of Hours:  6.00
Manual Reference:  12
Brief Description:  Finished riveting & sealing tank w/o baf
Installed vent line, riveted and sealed inboard rib. Instaled and wired capacitive senders, sealed connector on inboard rib and crimp connectors on cap plates, pushed grommets into ribs. Sealed and riveted T905 and T410 corner brackets on inboard rib.Used small stick for forming bead. Riveted and sealed T410 corner bracket in outboard rib. Stick works better than knife. Made small plate for tooling hole in outboard rib, riveted and sealed cover plate over hole.
