MIKE'S WEB SITE
Date:  12-31-2002
Number of Hours:  5.50
Brief Description:  drilling and more deburring on tank
Drilled strap bracket (W919) to final #19 size (#8 screws) on tank side. ** Need nute plates on tank side of strap Measured wing for twist- 1/8" - OK Remove tank from spar, drilled out all holes to proper size, including 1/8" bolt thru Remove T912 Attachment brackets from baffle NOTE: Drilling out "soft pop rivets" are a problem, tip sticks up, hard to drill out, new rivet remover was better, do different next time. Attached nuteplates to T912 brackets Drilled/deburred, counter sunk aft side of brackets, riveted platenuts on
