Michaels Web Site
Date: 6-8-2014
Number of Hours: 0.00
Brief Description: First flight no-go.
I was going to try a first flight today, but it was not to be.
Taxi testing went well. I got to the fuel pump and put in 10 gallons. I then tied down the plane and did a full throttle run-up. I only get 2,600+ RPM. I should be seeing more like 3.000 RPM.
So I re-set the pitch of the prop to be flatter (it's a ground-adjustable prop). Now I got just a hair under 3,000 RPM on a run up. Good.
But I still have a sticky throttle. In fact, it was so sticky I had to use 2 hands at times to move it forward! It was an 85 deg day, and the CHT's were getting to 400 on 2 cylinders. And to add to all that, my radio was intermitent.
So with all that happening, I decided not to fly. Our airport is closing for 2 weeks for runway work, so I'll use the time to work on the throttle, cowl, paint, comm, etc.
My daughter trying out the cockpit.
My daughter Sophia
My wife, Gail
Copyright © 2001-2020 Matronics. All Rights Reserved. |
