Michaels Web Site
Sonex Standard Gear
Cowl
9-27-2013
Oil filler door
- By watching the shadow of my finger through the cowl (looking through the cooling inlet) I marked the location approximately over the oil filler.
- I drilled a pilot hole (photo 1) to verify that the filler was centered below.
- Then I used the Dremel to cut out the flat-sided opening (photo 2).
- After sanding all the edges I put it over the engine and it aligned perfectly.
Pilot hole to verity location of filler below.
Rough cutout, per plans.
Finished cutout, with cowl over engine.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
