Michaels Web Site
Sonex Standard Gear
Cowl
8-11-2013
More fiberglass on cowl
Added fiberglass to the lower portion of the cowl. This time I used peel-ply (light green in the photo) so I could use a scraper to smooth out the glassing. This should give a smoother finish with less resin.
More fiberglass. Peel ply is light green.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
