Michaels Web Site
Sonex Standard Gear
Cowl
3-29-2013
Partial fiberglass lower cowl halves
Started fiberglassing the lower fuselage halves together. The engine/mount are in the way of doing the whole thing, so hopefully this will be enough to hold it together so I can remove the whole thing and fiinish on the work bench.
At prop hub
Lower cowl, below engine mount
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
