Michaels Web Site
Sonex Standard Gear
Cowl
3-28-2013
Prep cowl for fiberglass
Took the top cowl off so I can get inside. Covered up the seam at the bottom of the cowl, with aluminum tape. The resin doesn't stick to aluminum.
Then cut 2" and 4" wide strips of fiberglass cloth the use along the bottom seam.
Aluminum tape along the seam at the bottom of the cowl.
I cut 2" and 4" wide fiberglass cloth strips.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
