Michaels Web Site
Sonex Standard Gear
Re-check upper plugs
I needed to check the upper plugs. They are harder to get to than the lower plugs, so I'd been putting it off.
I removed the side baffles, removed the plugs, rechecked/reset their gaps, added anti-sieze to the threads, and reinstalled.
I checked the plug connectors to make sure the conductor was properly installed, which they were.
Everything was reinstalled.
I took the opportunity to add more zip ties to stabilize everything and secure to the engine mount wherever possible.
Upper right plugs
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
