I was planning to use the larger air filter on the left, but when I try to put on the lower cowl it is WAY too tall and the cowl hits the filter before it ever comes close to closing up. I either have to build a blister in the cowl to fit around the filter, or I have to use the shorter filter. I am afraid the shorter filter will not provide enough air flow to the carb.
