Michaels Web Site
Sonex Standard Gear
Oil Cooler Baffle
Took the 2 patterns off the oil cooler baffles, layed them out on .025 aluminum, and cut them out. Photo 1 shows one of the two patterns.
Finished the pieces' edges, bent them to shape, and added the pilot holes for joining to the existing baffles.
Set the new pieces in place and drilled the corresponding pilot holes in the existing baffles.
Pattern on left, cut and bent part on the right.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
