Brief Description: Completer rear and side baffles
- Deburred rear baffle and riveted.
- Laid out and finished the left baffle.
- Put the upper cowls on to check their fit. The cowl is very tight agains the cowl. Maybe too tight? Though it seems very important for a VW to make sure no air escapes the baffles, so maybe tight is good.
- With both upper cowls on I cleco'd them down the centerline again to test overall fit.
Upper left cowl against baffles.
Cowl against left baffle
Cleco'd the upper cowl together again to test overall fit.
