Did odds and ends to finish up all I can do on the engine before mounting.
- Installed the 4 cylinder head temperature probes - Reinstalled the intake pipes - Attached the upper rear spark plug wires.
Per photo #3, the upper left spark plug wire is TOUCHING the exahust pipe. I will ask Sonex about this, since it doesn't see right, given how hot that can get.
Attached all 4 cylinder head temperature probes.
Intake on, and exhast on temporarily for fitting.
I don't like how close the spark plug wire is to the exhaust!
