1. Did more wiring tonight... wire runs + connectors.
2. With input from other builders I finally realized that the AeroVee starter has its own starter solenoid (photo #2), so I don't need the one on the firewall! So I took it off (photo #1).
3. I also attached the power wires from the avionics (photo #3) terminal block.
I'm waiting for some more wire connectors so I can finish up the wiring. In the meantime I continue to update my wiring diagram, and my panel layout.
Below the ground bus used to be a starter solenoid. It is removed.
On the left is the solenoid that is PART of the starter.
Avionics master terminal block. Picture from under the glare shield.
