Michaels Web Site
Sonex Standard Gear
AeroVee
Oil sump plate
Photo 1 shows the flywheel and the accessory plate back where they belong.
Photo 2 shows the oil sump plate installed. It was on back order for over a month. After installing with the acorn nuts, I installed the oil temperature sender.
Accessory plate and flywheel back in place.
Installed oil sump plate & oil temp sender.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
