Michaels Web Site
Sonex Standard Gear
AeroVee
Assemble crank case
Photo #1: Installation of a thin layer of Permatex Form-a-Gasket #3 on all mating surfaces.
Photo #2: Another (blurry) view of the case with the Permatex.
Photo #3: The case halves assembled and all the nuts and bolts installed and torqued.
Cylinders are next!
Permatex Form-a-Gasket thinly applied to the mating surfaces.
A slightly blurry shot of the Permatex.
The case halves assembled and all the fasteners set and torqued.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
