Michaels Web Site
Date:  12-29-2013
Number of Hours:  5.50
Brief Description:  Canopy holes and hardware
So much done, for so few photos! There was a lot of on/off with the canopy to get it all done.
- Used the holes in the pilot-side strap to locate the holes in the frame.
- Pilot drilled the holes in the frame, updrilled them, and deburred them. Photo 1 shows the assembly before updrilling.
- Updrilled the holes in the canopy and cleaned the edges with the deburring tool.
- Added the exterior slide handle (photo 2).
- Added the slot in the canopy (photo 3) for the slide handle. I didn't quite finish cleaning it up, so there's still some more to do. I made the slot by drilling multiple holes side by side, then cleaning up with a fle and sand paper.
- To add the slide handle and do some of the other frame cleanup I needed to take the whole canopy frame off the airplane, so that's the state it's in right now.
Canopy strap and canopy pilot drilled and cleco'd
Slide handle riveted to the slide assembly.
Slot for the slide handle in progress.
