Michaels Web Site
Date:  12-22-2013
Number of Hours:  0.00
Brief Description:  Drill screw holes in canopy (pg 2 of 2)
More photos to go with page 1.
- Max Emmighausen (building a Waiex) gave me dulled drill bits to drill the canopy holes. In photo 1 I used a piece of wood held behind the canopy material to back up the drill bit.
- I used a total of 4 bits, from smaller diameter to larger, to get the holes to the right size. But the holes need to be enlarged so the canopy has room to expand. So I wallowed the last bit in the hole to enlarge it.
- Then I used my deburring tool to dress the edges of both sides of all the holes, to remove any stress risers.
- The outsides of the holes need to be countersunk, so I simply used the deburring tool to create the countersinks (photo 2).
- I put the canopy loosely back on the frame. I'll re-tape the canopy and locate the holes on the frame next time.
Dulled drill bits through canopy into wood backup
Cleaned both sides of the holes with the deburring tool, but also used it to countersink the outside.
Canopy loosely laid back on the frame. See how the holes align with the canopy frame.
