Michaels Web Site
Sonex Standard Gear
Finish canopy frame
Today I needed to drill and rivet the corner brackets to the horizontal frame members. With the canopy frame fully in place:
1. I marked the locations of the pilot holes in the horizontal square-section frame members.
2. I took those members off the aircraft and to the workbench, to pilot drill them.
3. Then I re-assembled the whole frame again, and set everything per the dimensions and offsets in the plans.
4. And then I drilled through the pilot holes, into the round steel corner brackets, adding clecos as I went.
5. Then it was back to the bench with the whole assembly, where I took it apart once more, deburred everything, and put it back together (photo 1).
6. Photo 2 is the frame fully assembled, laid loose on the cockpit.
Canopy frame on the bench for updriling and riveting.
Completed frame, in place.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
