Michaels Web Site
Date:  10-23-2013
Number of Hours:  3.00
Brief Description:  Finalize rear bow
I did a little more trimming of the bottoms of the rear bow.
Then I located the horizontal brace by simply putting a short bubble level on top of it, and moving it into place (with the rear bow in place on the fuselage). With each end just touching the bow I marked the centerlines on the bow.
Then I took everything to the workbench and taped the aluminum down flat (photo 1). I then put a gusset on the assembly and marked the hole locations with a Sharpie (photo 1).
I drilled the first few holes so I could put clecos in (photo 2), then I put the whole assembly up on the fuselage to verify once again, before drilling the rest of the holes.
After checking, I updrilled all the holes, deburred, reassembled, and riveted. The end result is photo 3.
I drilled pilot holes in the front face of the bow to attach the steel corner brackets. I'll do tha work tomorrow.
Bow and cross brace with gussett hole locations indicated.
And with a gusset in place with pilot holes.
The end result.
The end result.
