Michaels Web Site
Date:  5-4-2012
Number of Hours:  3.00
Manual Reference:  D01
Brief Description:  Windscreen - begin installing on fuselage
- Balanced the left aileron. It was close to balanced when I started, so I did not need to remove much lead.
- Finished painting the bow strap.
- Peeled the protective plastic of the interior face of the winscreen. It would be hard to remove later, and once installed there shouldn't be much to scratch the inside.
- Began installing the fasteners. I can't do the bow yet, since I need the bow strap, and the paint hasn't dried.
- I found the machine screws called for in the plans were just too short to work. So I'm using the S50 (longer) machine screws instead. But now I will need to order more hardware.
Forward edge of windscreen
First few fasteners at the aft end of the windscreen
Same location, from inside.
