Michaels Web Site
Date:  4-25-2012
Number of Hours:  0.00
Manual Reference:  D01
Brief Description:  Windscreen - trim & drill
- With everything in place I noted some tweaks to the trimming that needed to be done, so I removed the windscreen again, cut on the band saw, filed, and then sanded the edges.
- Reset the windscreen once again, clamping in place.
- Drilled all the holes along the windscreen edges where they meet the fuselage sides.
- In photo #3 you can see the Bow Strap that does not reach the fuselage. It is supposed to be just about touching the stringer below. I cut this strap per-plans, many months ago. Since I set the bow higher than the plans, I will need to lay out and cut a new, longer strap.
Getting there!
Another view of the clamped canopy.
Windscreen at the forward corner, aligned with the fuselage side.
Bow strap does not reach because bow is set higher than plans, and I cut the strap months ago.
