Michaels Web Site
Sonex Standard Gear
Fire sleeve & connections
Slid the fire sleeve onto the fuel line and the 2 oil cooler lines, and secured them with clamps (photo 1).
Put teflon paste on the fuel threads and tightened down all the connections.
I'll need to do a fuel flow test soon, and check fuel flow and check for leaks.
Fire sleeve on fuel and oil cooler lines.
Fuel line in place from carb to fuel strainer.
Fuel line connected to fuel strainer.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
