Michaels Web Site
Sonex Standard Gear
n/a
Overflow pan
- Applied the last coat of clear coat to the wing tip.
- Added a stainless steel patch over the hole that the overflow tube comes out of. After it dries I'll add fire caulk. Photo #2.
- Installed a bead of fuel proof sealant (unfortunately it's black) at the gaps around the overflow pan, including around the filler neck (photo #3).
Last coat of clear on this wingtip
Clamps holding ss patch in place (hard to see here)
Black sealant at joints
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
