Michaels Web Site
Date:  2-29-2012
Number of Hours:  2.75
Manual Reference:  C01
Brief Description:  Rudder cable + cable fairing + prime paint
- Finished making a longer fitting to reach from the right rudder pedal to the rudder cable. Right rudder cable install completed, so NOW THE RUDDER SYSTEM WORKS!
- Installed the left rudder cable fairing at the rear of the fuselage. Started the right fairing install, but didn't finish.
- In between rudder cable work I prime painted the outside end of the aileron. It only has a stripe, matching the wing tip, across the end of it. The photo below is after the first coat. A total of 4 light coats were applied.
Left rudder cable fairing installed
Layering on the primer at the end of the aileron
