Michaels Web Site
Date:  2-24-2012
Number of Hours:  1.00
Manual Reference:  C05
Brief Description:  Control horn assembly
- Drilled the 1" dia hole in the firewall for the later installation of the fuel line (photo #1).
- The instructions for the control horn assembly is to ream out the bushings. But they are 5/8" diameter; who has 5/8" dia reamers??!! So instead I used paint stripper and sandpaper to remove the paint from the horizontal shaft that goes through the bushings. Once I did that the shaft was snug but free to move, just as the plans call for.
- Test fit the entire control structure together.
1" dia hole drilled and filed, for later installation of fuel line.
Control assembly in bushings. Not paint removed from shaft.
Test fitting the pieces.
