Michaels Web Site
Date:  2-17-2012
Number of Hours:  2.25
Manual Reference:  L05/C01
Brief Description:  Trim cable & Brake Parts
- Flipped the wing over and finished prime painting.
- Made 2 parts from L05. Both parts are only made if you are making a tail dragger: L05-09 (photo #2) and L05-11 (not shown). both are made from 1/2" x 1/2" alum bar stock.
- Inserted the inner wire for the elevator trim tab, and temporarily installed it in the clevis bolt (photo #3). It's only temporary because I need to get the controls installed in order to set the neutral position of the elevator and the trim tab.
Finished priming the wing tip
Made 2 parts on L05 (parts are only for standard gear)
Trim lever w/ cable in place
