Michaels Web Site
Date:  11-25-2013
Number of Hours:  1.00
Brief Description:  Wheel pants on brake drum
I pre-drilled pilot holes in the inner brake drum per the holes I had located previously, with the wheel pants in place. I could only drill THREE of the suggested 4 holes. One hole location is fully behind the gear leg and there is NO way to get a drill or a fastener in there.
I had to take the entire wheel/brake assembly off. There was no way to tap holes, working around the landing gear leg.
I had a devil of a time tapping the drum. In fact I was unsuccessful after 1/2 hour of trying. I will try again tomorrow.
Wheel off. The rest of the brake assembly had to come off, too.
I had a devil of a time tapping the drum. In fact I was unsuccessful after 1/2 hour.
