Michaels Web Site
Date:  7-7-2012
Number of Hours:  0.50
Manual Reference:  L01
Brief Description:  Axle assemblies
- Drilled a 3/32" pilot hole in the axle assembly, for use later when drilling through it, and the titanium gear legs.
- Used a sacrificial section of steel pipe (photos #1 & #2) given to me by Max Emmighausen, to bolt on the cable guides (which come flat) and use a rubber mallet to bend them around the pipe, to get the correct 5/8" radius. The result is photos #1 & #2.
- In the bending process some of the paint cracked and flaked off, so I sanded off the loose stuff, cleaned the surfaces, and prime painted those areas.
- On the axle assembly the tabs for the brake drums have a weld at one end that interferes with the nut that needs to go there, so I used my Dremel tool to carve out the fillet weld until the nut would stil flat (red pen is pointing to the area in photo #3).
- Again I prime painted the area and will add black paint afterward.
Bending the cable guide washer
A closer view
A closer view
Carved out part of the weld, so the nut will fit
