I am using castelated nuts to secure the rod end bearings in place. They will get cotter pins when finally installed. Sonce the fittings could be subject to rotation, I decided on the castelated nuts.
Now I need get the bolts welded into the chromoly tubing.
With bolts taped in place in the chromoly tubing, set fit to make sure threads would work
Rod end bearing at rudder horn; temporary duct tape holding bolt in tube
