Installed grommets through aircraft structures, to run wiring and the antenna coax. The difficult part was getting as far into the tail cone as I could to install the grommets. It would be tight for a 5 year old in there; for me it's agravating and painful. But I got it done.
All that is left to do are 3 wire splices, then to attach the GPS and ADSB box power leads to the "ADSB" switch on the panel. Hopefully I can finish tomorrow.
3 hours total today.
Grommet for wires & antenna coax
Antena coax installed,
Grommets in aircraft structures, back to tail cone.
