Michaels Web Site
Date:  2-22-2014
Number of Hours:  4.00
Brief Description:  ELT Mount
I spent 4 hours on this today.
- Took measurements and made a paper pattern.
- Test fit the pattern and finalized it.
- Spray-cemented the pattern to some .032 aluminum & cut out the shelf.
- Used the bending brake to bend the long angled edge, and a small tab at the narrow end.
- Used duct tape to hold the shelf in place, then drilled holes from below (I have no skins on the bottom of the plane) with a long drill bit.
- Updrilled all the holes.
- Removed the shelf and deburred everything.
- Located the ELT bracket on the shelf and drilled for the 6-32 screws called for.
- Cleco'd the shelf in place. Will rivet tomorrow.
Notes:
- The TSO requires the unit to be installed to the aircraft structure, or supports directly attached to the aircraft structure.
- The shelf design is very similar to the triangular reinforcing for the seatbelt attac points.
- This new shelf sits on the longeron down one whole edge.
- The opposite edge is turned down to add stiffness.
- The forward part of the new shelf rests on top of the channel that goes from longeron-to-longeron.
Structural shelf with ELT bracket attached.
Testing ELT location.
ELT shelf in 2nd bay behind passenger.
