Michaels Web Site
Sonex Standard Gear
Transponder static connection
The static line needs to go to both the transponder and the EFIS, so I needed a Tee fitting. The static line to the transponder is narrower than the one to the EFIS, so I had to buy a tee fitting that had two 1/4" ends and a single 1/8" end.
Tee fitting to the left of the word "STATIC"
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
