Michaels Web Site
Date:  5-11-2013
Number of Hours:  3.00
Brief Description:  More wiring
Worked on a lot of miscellaneous wiring, including:
- The pin connectors from the RDAC would not fit through my firewall fitting so I had to disassemble the pins/sockets, put the wires through, and reattach the pins/sockets on the other side.
- Attached the engine block ground cable to the ground bus.
- Cut the RDAC power and ground wires to length, label their ends, and attach the appropriate connectors.
- Attached the RDAC power wire to the avionics power bus inside the cockpit.
- Made a power bus for the engine-side of the firewall, even though I don't have anything that needs to be powered from it at the moment. It's easier to do it now then later, if some power requirement comes up in the future.
It will all make sense and look pretty eventually. Really!
