Michaels Web Site
Date:  5-2-2013
Number of Hours:  1.50
Brief Description:  Panel rivets + wiring
- Riveted the corner bracket at the right side of the panel.
- Installed the GPS antenna for the EFIS. It's stuck on the glare shield with double sided carpet tape. I drilled a hole big enough for the connector to get through, and installed a rubber grommet to protec the wire.
- Spent time laying out the wiring harnesses for the EFIS, comm radio and sensors, to get a feel for what has to go where, and to see which wires will be long enough and with will need to be spliced.
Corner bracket attached.
GPS for EFIS, with wire through glare shield.
GPS stuck down with double sided tape. Rubber grommet in hole.
