Michaels Web Site
Date:  9-18-2010
Number of Hours:  0.50
Brief Description:  Trim tab; Finished T02
Located and drilled pilot holes in the elevator usin the pilot holes already in the trim tab hinge. Then updrilled, deburred and riveted.
Now I am done with T02 (except for drilling the hinge pins for the tiny cotter pins; I will later need remove the elevators, and the hinge pins are a bit of a pain to get in, so I'll wait to do the cotter pin holes until I put the hinge pins in for good).
Then I had to clean up all the rivet mandrels lying on the floor. I leave the cup off the back of my rivet puller because it seems to just cause problems (mandrels fall back into the body and get the jaws stuck), so they all just fall to the floor.
Trim tab drilled and cleco'd
Trim tab done.
Trim tab done.
Lots of rivet mandrels to pick up.
