Michaels Web Site
Date:  9-10-2010
Number of Hours:  2.75
Brief Description:  Elevators + Elevator Horn
Worked on the left and right elevators, getting all 4 main ribs located and pilot drilled.
Then went back to the elevator horn. The inside 2 ribs get installed on the horn first, then the whole assembly gets mounted to the 2 elevators. I got all the pilot holes drilled through the ribs, then got all the holes on the left side up-drilled for the rivets. Tomorrow I'll updrill the right side, debur everything, and rivet everthing.
Then I'll be able to do the critical layout of the elevators with the horn and with the hinges.
Test fitting the horn with the elevators spaced at 78
Test fitting the horn with the elevators spaced at 78"
After pilot drilling all holes, then updrilling the left side
The elevators spaced at 78
The elevators spaced at 78" out-to-out
