Michaels Web Site
Date:  9-9-2010
Number of Hours:  2.50
Brief Description:  Right, then back to left, elevator
I set the center rib in the right elevator, but it didn't lay out right when the skin was closed up. I needed to position it differently before drilling. Soooo....
I made a new rib, reset it, and drilled the top skin holes in the rib.
I then went back to the left elevator, which in a previous post I noted didn't look so hot. I made 2 new ribs, set them better before drilling, and got the center rib drilled. The second rib is ready to go for tomorrow.
So I'm not much further than I was at the end of last night, but both elevators look a lot better, so I'm happy.
The left elevator with one new rib installed, and one ready to install
The right elevator with 1 new rib
Both elevators on the work bench
